We are going to pull our fishing boat to the lake with our 36' class A. DW thinks we should be able to back the class A with boat down a boat ramp to launch. I said "never seen that done, must be a ...
I have a 36' Monaco Dynasty and a 24' Sea Ray Sun Dancer. I have launched all over the place. Your brakes will likely screech backing down a steep ramp as they aren't used to be used in that direction. On a flat ramp make sure you know where to stop. If you go into the water too deep you could dunk your side radiator fans which would likely damage them.
