Not sure if this will help the original poster. I have a 2000 Monaco on an F53 chassis. Body roll when turning or going around a curve was white knuckle especially going downhill as it really felt like it was going to tip over. I started on a quest to reduce this. Started with the cheap handling fix but did not notice a big difference like some folks report. Next I switched shocks out to bilstein. No real difference that I could tell. Changed bushings on sway bars as they were getting worn (one was really bad). Again, nothing earth shattering. Decided to get a little more aggressive and purchased both a front and rear track bar to lock the frame to the axle's. This did improve the roll quite a bit however I still have those moment where the lean seems too much. Mostly going down steeper grades around corners. I'm tempted to do the last thing possible and install airbags or the sumosprings. Not sure which route to go but I'm a bit mint. obsessed at this p
