DSDP_Don
Feb 19, 2015Explorer
If you're prewired, the loom will USUALLY consist of four wires, similar in color to the wires on your controller.
The issue with DP's is that they don't use a brake switch which triggers the braking system. They use pressure sensors on the firewall. You need something to trigger the system and make sure it doesn't come on with the exhaust/engine brake.
