bigdisplay
Mar 17, 2015Explorer
PCarnathan wrote:
Still no luck. We spent an hour looking under, over and around the dashboard to no avail. Tekonsha sent me some pictures of the plug and specific wiring instructions, but if I can't find the wiring I'm still stuck. As for actuating the controller with air brakes - Even air brakes activate brake lights; and that's how the controller receives the signal.
The search will continue. Thanks for the answers and suggestions.
Pat in Menifee, CA
www.patcarnathan.com
DID??? you look at the 7 pole connector and make sure you have the Blue brake lite wire????????
If its factory wired you will have a Blue wire for the brakes, red or black for the charge,white for grounds,BRown for tail/run,yellow/green for turn/brake lites and another wire if Back up lites are prewired. so SIX or SEVEN wires go look
38,783 PostsLatest Activity: Sep 21, 2026
