Latimer's avatar
Latimer
Class A Elect.Help,Help,Help,
Stoped at son`s,last night all things worked///
To day the slid outes,the jacks,and the dash air do not work.
I have checked every fuse I could find.
Need help can`t move.
Thanks
  • Check left side fuss box there is a hi amp 100 amp braker with a red
    button pushed and lever come down at bottom. no power.
    Thanks
  • Is there an electrical panel in the front left compartment? Have you checked for power on the main terminal there. It should be fed from a main fuse/circuit breaker near the engine electrical panel.
  • Iam pluged in to shore power.Eng, runs,
    Checked and cleaned batter post.and rotated switch to off and back to on. no power???
  • What is the make and model of the chassis?
    Normally the jacks and slides come straight off the batteries except the controls could come off battery control center. The dash air should come off the battery control center or the chassis fuse block.
    I am guessing the rig starts.
    Have you tried cycling the battery disconnect switch? Off then back to on.
  • Were you plugged in all night? If not, could the batteries be flat?
