TugCE
Sep 24, 2018Explorer
Class A Fire
Here's an older video of a Class A Fire that shows why a working Pressure Relief Valve on our Propane Tanks is so very important. You can start watching it at 5:20 as that's right around the time t...
FloridaRosebud wrote:mtofell1 wrote:
Pretty nice view in the landscape behind the coach..... I'm guessing he had pulled a good sized hill and got something too hot. Yeah, those firefighters seemed pretty un-phased by the flames exploding/shooting off the coach. I couldn't tell if it was gas or diesel. If gas, are they not afraid of the tank exploding?
Actually, gas tanks usually only explode in the movies (not always, but in most cases). I'm a certified fire investigator and engineer, and a gas tank with gas in it is above the upper explosive limit (UEL), as there is not enough oxygen in the tank to get to the right mixture. It's when the heat from the fire causes the tank seams to split is when it becomes an issue, and it's usually not an explosion but a huge flame-up due to the new combustible fuel adding to the fire.
Propane, OTOH, is a way different beast....
Al
