was_butnotnow wrote:
OK I'm sure this has been beaten to death... BUT as a 5th wheel owner just starting to look a getting a used 2006 - 2012 Class A. About 35 ft is a gas engine powerful? I see Ford V10 and Chevy V8 Is a V8 powerful enough in a 35 ft unit? Or should bite the bullet and go with a diesel?
depends on what your personal wants and expectaions are. Mid level to mid upper end diesel pushers quality wise,power wise, ride wise
etc are far far superior to a gasser BUT you can buy a brand new gasser for less than the price you will pay for a 2009 ish diesel pusher.So if your serious about owning a A MH and you want the best power to weight ratio, best handling, best ride and built to higher standards brake,frame power train and suspention then a diesel pusher is the only way to go especially if your running in the mountains and pulling a toad.My 450HP isl 40 ft 4 slide unit blows by gasser going up mountain passes
