livoniaben's avatar
livoniaben
Class A gas w/toad help
My current RV is a travel trailer.
Would like to upgrade to a used gas class a about 10 to 12 years old in the 34 foot range with ability to pull a TOAD.
Looking for suggestions/tips to help me make a decision, also on a good choice for a TOAD.
Thanks for any help you can provide.
Ben
  • We bought a used, 35' class A Winnebago gas unit a year ago. We tow a 2014 Honda CRV. It is well under the 5000 lb tow limit (about 3500lbs) for our motorhome. Some items to consider:
    1. 2015 CRVs and later cannot be towed 4 down due to their new transmission.
    2. The owners manual says don't tow at speeds greater that 65 mph
    3. There is a 3-5 minute procedure to go through before towing each day. You also need to do that when towing more than 8 hrs. The procedure consists of starting the car and running through the gears.
    4. You need to either pull a fuse or install a fuse disconnect switch (that is what we did) for prolonged towing. Otherwise you may drain the battery.
    None of these items are problems for us. It is a good, light tow car.
