- JaxDadExplorer IIIMaybe it’s just me, but one line from that story caught my eye.
“The 40-foot 2007 Beaver motorhome, which was pulling a trailer, was occupied by nine members of the Edelbrock family of Snohomish County.”
I can’t say I’ve ever seen a motorhome with seatbelts for NINE people. I wonder if some of those that didn’t fare too well weren’t buckled in when this happened. - DiskDoctrExplorerHold solid, small adjustments, avoid what you can, put the 'meat' (strongest points of the frame) where you need it. Pray.
No guarantees. Prayers for the family and all affected. - timmacExplorer
wcjeep wrote:
This popped up on my local news feed. Class A dissambled from motor vehicle accident. Horrible for those involved. No cause noted.
Ellensburg, Wa accident
This is a sad story.
However the motorhome was a 2007 and I wonder what was the age of tires and brand, reminds me of my neighbor with his motorhome that's a 2008 like mine but yet he still has the factory tires cause they have low miles and no signs of dry rot yet, it bothers me every time he heads out to go camping, I have replaced all mine but yet to convince him to at least get 2 new front tires but he is hard headed and wont do it.. - J-RoosterExplorerI failed to mention in previous post that tires possibly being the cause was from eye witness reports and the Washington State Patrol on scene investigation. The WSP did not mention if the tire problem was from the RV or the cargo trailer it was pulling. The RV and Cargo Trailer are under lock and key in storage until further investigation is done by the WSP and the NTSB. There going to go completely thru both units!
- J-RoosterExplorerI read a article from the Yakima newspaper and the reporter said he talked to the Washington State Patrol, and the WSP said they suspect tire problems caused the accident! I’m now retired but used to drive truck from Kent to Ellensburg I know that stretch of I-90 very well. If that RV and trailer would have been going a little faster or slower it would have been possible for it to have gone into the Eastbound lanes of I-90. The RV went in between the two bridges down into Wilson Creek. The WSP was shocked when they pulled the driver and passenger out, then discovered 7 children inside the coach either deceased or hurt! A total of 9 people were in that RV.
- Cloud_DancerExplorer II
mike brez wrote:
dodge guy wrote:
Very sad. But a lot of people can learn from this! Always check your tires. And replace 5-7 years. I’ll bet that coach was running on OE tires!
The trailer had nothing to do with the accident! Watch the other you tube video of the guy in the MH that blows a tire. Not much you can do once it happens!
If it's the one I'm thinking were the trucker captured it on his dash cam I think the trucker said he was going 65mph RV passed him pretty quick.
This one
Please allow me to take exception to "Not much you can do once it happens".
Does he mean you can't control your motorhome once the front tire blows out? You see, I'm totally convinced that the main cause of failure to remain in control is instant BRAIN FREEZE (for a few seconds). The thing is, you do NOT have ANY time to waste.
You look at it this way: What is the driver doing the last 5 minutes BEFORE the first sign of a blowout? I believe the driver was steering the motorhome, and has his hands on the steering wheel. I have to believe he knows how to do that. So, why does the driver NOT keep on working the steering wheel as soon as the air starts going out of the tire. In the above video, the driver does a classic "brain freeze" error,...he doesn't even turn the steering wheel to the right, not even a little bit. In fact, just the rolling resistance of the flat tire is allowed to rotate its spindle to the left and it in turn rotates the spindle on the right,....the traction of the right front tire is used for helping turn in the wrong direction. The MH is actually steered right into the ditch(median). Yes, the fact that the right front drops a bit, AND the body rolls a bit to the right,....proves it to me. I've actually done it on purpose in my Dutch Star,.....twitch the steering wheel to one side at 60 mph. In two seconds (2) it's into the other lane!
Once you're on the grass, pointing away from your lane, there's no recovery. - path1Explorer
azdryheat wrote:
Forum members get the benefit of these educational videos. But what about non-members? I would like to see every large RV driver go through what I went through to get my CDL: studying the manual, passing the written(s) and a driving test. Cali and some other states have started adding endorsements but, in Cali's case, only for DP's longer than 40' and the heavier trailers. All motorhome drivers should get the training.
Anybody can go down to their local Commericial DMV office and get a free copy of the same study material required for the semi drivers. There are also plenty of practice tests on the internet to see if you learned anything. Anyone know the proper way to test their airbrakes? There's videos for that, too.
Point is there is plenty of material/videos available so that everyone can be a better/safer RV driver.
When our state was thinking about an endorcement for what you mention, the RV dealers beat it down to state Capitol to protest, and how much tax money the state would lose if public couldn't buy whatever they wanted to buy. End result...lots of people shouldn't even be on the road in anything. - wcjeepExplorerIt's the possible tire situation that caught my attention. Jalopnik.com has been reporting steadily on the Goodyear G159.
- mike_brezExplorer
This one - dodge_guyExplorer IIVery sad. But a lot of people can learn from this! Always check your tires. And replace 5-7 years. I’ll bet that coach was running on OE tires!
38,759 PostsLatest Activity: Nov 09, 2025
