- IvylogExplorer IIIUnfortunately they are probably old enough to have multiplied.
- dodge_guyExplorer II
down home wrote:
I'm not sure our GPS had low bridge clearance in it. Co-pilot, on back roads and strange/new territory always s n the watch for signs and the overpasses themselves.
We encountered several in Indiana and other places. Missed signs a couple of times but overpasses are generally marked, In Ga and Tn some Civil War era underpasses, when buggies and wagons were the rule, slipped u on a couple. Saw from a distance we could not clear though. 'm not sure what will be our next Motor Home but on board GPS might not have low clearance over passes indicated, so considering a GPS for over the road truckers. Even then it is possible that some may not b indicated. Co-Pilot duty things to help watch for is lwo overpasses.
I had the Co-Pilot app and it is the worst GPS I have used. It sent me some a road in WV that would’ve been questionable in a minivan with a PuP. Twists and turns that rival raids in the Rockies! I’m usually pretty good at looking at the map beforehand but I missed that one!
Next year I’m getting a Garmin RV GPS. But you still need to watch the road! - down_homeExplorer III'm not sure our GPS had low bridge clearance in it. Co-pilot, on back roads and strange/new territory always s n the watch for signs and the overpasses themselves.
We encountered several in Indiana and other places. Missed signs a couple of times but overpasses are generally marked, In Ga and Tn some Civil War era underpasses, when buggies and wagons were the rule, slipped u on a couple. Saw from a distance we could not clear though. 'm not sure what will be our next Motor Home but on board GPS might not have low clearance over passes indicated, so considering a GPS for over the road truckers. Even then it is possible that some may not b indicated. Co-Pilot duty things to help watch for is lwo overpasses. - mountainkowboyExplorerWhoever was driving that rig, shouldn't be driving that rig. You have to completely clueless to do that.
- notevenExplorer IIIMetric …. aaaahahahahahahahahahahahahaaaaa
- 69gpExplorerI would be looking at age as being part of this accident. But its still the drivers fault and there is no excuse. I know the height of my RV and and I am always careful with bridge heights. With that being said when I am on side and country roads I am always looking up for that low hanging branch. The bridge that was hit is no different than slowing down and avoiding a hazard in the road. You just don't drive over a foreign object. Slow down, stop or swerve off to the side. Low hanging branch Slow down , stop or serve to the side.
- Timmo_Explorer IISome people have a problem visualizing size. Men are usually accused of thinking certain things are bigger than they really are, and women, well....lol.
- NamMedevac_70Explorer IIThe trucker's road directory of low bridges and overpasses is most helpful and it does pay to read the signs if driving a tall vehicle.
- kenbertExplorer
rlw999 wrote:
kenbert wrote:
Glad to here they will be OK, but my takeaway from this is that 2013 Diplomat is built like ****. It disintergrated on impact.
I think all Class A's (except for the ones built on a real bus chassis) would fare the same, they are essentially a wood and fiberglass box on top of a steel chassis. They don't usually stay together well in serious accidents.
This is one reason I would not buy a Class A -- I like being in a crash tested cockpit with airbags in a Class C. Plus the cab roof is only around 6 or 7 feet off the ground, so even if I hit a low overpass, worst case I'd lose the overcab bunk.
I have a cage on mine built in 1995 when quality counted. - dodge_guyExplorer IIUsually the higher end coaches and some mid level class A’s have a steel cage around the driver and passenger. Not that it would’ve done much for protection!
38,764 PostsLatest Activity: Dec 23, 2025
