Gjac wrote:
If you want to stay short and boondock, water and storage will be important. Of the 4 MH's you listed I would go with the Newmar Baystar because I think it will have full basement storage and hung side walls . Check the FW capacity you will need a minimum of 60 gals for two people for a weeks stay. I would also look at others like the Damon Daybreak,some models have full basement storage plus a large rear pass tru storage bay that goes under the rear bed and 80-100 gals of FW.
Yeah i looked at FW they are all doable smallest tank is in Pursuit 50gal and biggest in Palazzo 95gal and others are in between.
I have created coring system for each of the things that are important to us with scores 1-5 and then assign them based on the values the RV with most points wins (out of these its Mirada 32SS that has scored most points) :)
