bmwdriver2019 wrote:
but , when it comes to safety , and my own, ill nit pick
You seem to think safety. I have NEVER(43 years, hundreds) of driving both Dodge and Ford had an issue with hi way driving that made me think to get home and worry. Just like a BMW, you can install/add all sorts of chassis modifications to make the handling better. A LOT of people do add suspension modifications to Class A Fords. Not so much because they worry about safety, but because they want to improve the handling characteristics. You think your Ford does not handle safely? I wish you could go back to the Class A Dodge M series chassis that were used until Dodge went out of the chassis business in 1979. THOSE did have major handling problems. The OEM's do a pretty good job of trying to distribute the weight. Buying a Motorhome is NOT like buying a highly engineered Automobile. Number 1, you could NEVER afford a Motorhome built with the engineering of a BMW. Are positive your motorhome has never been wrecked or had a bad chassis/suspension wreck?
1. Have you had all 6 tires balanced?
2. Are you positive that the alignment was done correctly?
3. Are you running at the correct PSI in your tires?
4. Have you had your weight correctly done by the companies that do that and then give the 4 corner weights with THEIR recommended PSI in the tires? Doug
