dodge guy wrote:
I would get a second opinion on the front end work. unless you have been abusing it, I don't see an F53 needing tie rods and king pins at such low miles. especially on something that is used mostly on highways.
As far as tires....just shop around. Ive heard good things with the Hankooks.
I went with Toyo on my Workhorse. No complaint. The thing about Toyo's v/s say Michelin Toyos do not last as many miles.. But on an RV that is almost never the reason for tire replacement (miles) YEARS is the reason most RV tires get replaced. So why waste money on the HIGH MILLAGE tires when you can save money and the tread will never wear out.
Page 2: Ford Dealers
Wife had a Mercury Tracer.. It was running rough (Will tell why) took it to local Ford Dealer for tune up (not help) and later said Diagnose and repair.. They told me the fuel pump was leaking. I ask to look, sure enough there was evidence of a leak at the top of tank where the hose connects to the pump outlet.. FRESH leak, no evidence that it was leaking when I pulled in.. 300 to replace the hose they punctured and the dealer is now padlocked by the State of Michigan (Hey. not a good idea to rip off a police dispatcher who is friends with the Secretary of State Investigator).
Oh. the rough running.. Part of a Tune Up on that car is replacing the spark plugs and the wires.. They did not replace the wires.. I finally did and varroom no problem.
I normally dealt with a Chevy dealer (My car was a chevy) and never had that kind of problem there. DID have one problem.. Well two. but one they took care of it. no questions asked, and the other one.. Well.. I did not pay for it so no rip-off. (They simply did not know how to fix it.. I finally figured it out and it got fixed).
