PCronin68's avatar
PCronin68
Class A Tire Recommendation
Looking for class A tires for my 2014 Fleetwood Bounder 34B. Unfortunately my RV with 25k miles already needs tires. It is at Ford dealership for a general checkup. Dealership says it needs tie rods and king pins for front end along with 6 new tires ($2,900 w/out cost of tires). I have noticed that the tires are wearing on the outsides edges so I wasn't surprised. However, I am surprised all this work for a 2014 already. Dealership says the Goodyears that are on there now are $668 a piece. I am a FMCA member and they have Hancock, Continental and Michelin ranging from $305 to $430. Any thoughts?
  • Over the past 20 years I have run Toyo and Sumitoma and have been happy with both of them. I shopped around for best price but have never used Hankook although I have heard good things about them. Just put on 6 new Sunitomas for $1860.00 out the door so I believe, if you shop around, you can find a better deal on tires.
    As far as the tie rods and other front end work, I would recommend another shop for evaluation. Back in the day I drove a 1999 Bounder 68,000 miles without any front end work. Just sayin. Best to you in your quest. Happy travels. Arnold
  • Ivylog's avatar
    Ivylog
    Explorer III
    Run to another shop... GY are noted for edge wear. I’ve had good service from Hankook on my DP.
  • PastorCharlie wrote:
    A second opinion is needed, it is unrealistic for a six year old vehicle with 25,000 miles to need kingpins, etc.
    X2 I was told the same thing a few years ago. Got a second opinion from a workhorse shop. Told me I had a blown shock and needed a good wheel alignment. I had them do the work and problem solved.
  • Your 2014 is 6-7 years old and that is the life of RV tires. I used FMCA for my tires a few times. Great deals
  • ^^^ 2 post above - YES!!!
    Even if you have been abusing it not a chance in heck that thing needs new tie rods and king pins.
    The Goodyears are known to river so don't let them tell you a worn out front end is causing it.
    Someone is being a bit less than honest IMO.
    As to the tires, Hancock & Continental make a nice tire, personally I'm not buying Michelins.
  • A second opinion is needed, it is unrealistic for a six year old vehicle with 25,000 miles to need kingpins, etc.
  • I would get a second opinion on the front end work. unless you have been abusing it, I don't see an F53 needing tie rods and king pins at such low miles. especially on something that is used mostly on highways.
    As far as tires....just shop around. Ive heard good things with the Hankooks.
  • Thanks...looks like FMCA has Hankook RV tires Model 3002314 245/70/R19.5 at $298 seems cheap. Not sure how they compare to others
  • If you're talking about Hankook, they're good tires. If you're talking about Hancock, I'm not familiar with them.
    Several years ago I replaced the Michelin tires on our 96 Southwind with Hankook. I think it is a better tire.
