Golden_HVAC
Jul 30, 2013Explorer
Look under the dinette seat for the fresh water tank. Sometimes if there is a couch, then they will put the tank under there. While a inside water tank has the pump inside, and it is a bit noisier, the benifit is of course it will stay warm all winter.
Most class C and B will have a grey and black water tank underneath, not in a heated basement storage like a class A. So your tanks might freeze. This might damage the drain valve and piping, but might not. You can always drive out of the mountains, let it sit in the 50's weather of your hometown for a day or two, then drain at your local RV store, or some gas stations have a dump station, some at the City Sewer Department, or local RV storage lot.
With the Olympic catalytic heater, you do need to keep a roof vent open about 1/2" and it helps to have a Maxx air cover over the top of the roof vents. I have used one safely since 1994, without problems, and at 19F outside, I keep my RV around 70F inside with minimal furnace run time. A 20 - 23' long RV should do better. Especially if you get a windshield cover (keeps the early morning light out too) and perhaps hang a blanket over the front drivers area. The dash air vents will let in some air all the time, depending on the wind direction and strength, it can be a bunch of air.
Remember to open the roof vent and window about 1/2" whenever using your stove. While not recommended to heat the RV, if you happen to cook something in the oven, it will warm the RV significantly, and with it's 19,000 Btu burner will warm it quickly.
Also consider making coffee on the stove. You can find perculators at some locations, and it works OK. However many prefer this way. Get ahold of a old Mr. Coffee filter holder. (garage sale, or a coffee maker that has a broken caraffe, and you don't use it anymore.)
Put in a filter and get out your coffee cups +1 extra. Add a tablespoon of coffee, and set over your first cup, add about a cup of boiling water, and then move to the next cup, add a tablespoon more coffe, and continue around the table, until the last cup. The coffee will continue to drip a bit, so the last cup will keep things dry, and you can start over anytime with more hot water.
Coleman used to make a toaster that fits on top of a stove burner, however I was never impressed with the results, and prefer to butter my toast and cook in the oven broiler.
The people who wrote in about using space heaters and a electric blanket have "Great" tips "If" you are in a campground or have 120 volt power to your site. However it will not work at all if you are in the parking lot of the local ski resort, and they are not offering 120 volt power to it's customers. Thus the Olympic Catalytic heater.
You can bring along a hair dryer, 1,500 watt heater, and perhaps a electric toaster or toaster oven, just only use one at a time if you have a 20 amp circuit that you are plugged into. Or two at a time if you have a 30 amp RV style hookup. Each will draw close to 12.5 amps.
I liked running two electric heaters on low heat setting, one in the front one in the rear bedroom, that would move to the bath when occupied. They have thermostats, and I can leave them on at night, or while out sightseeing.
So you might ask - what is more expensive - gas furnace or paying 9 cents per KW for a electric heater? it takes 22 KW of electric to make 80,000 Btu's of heat, about what 1 gallon of propane will make - given the furnace is about 80% efficient. 22 KW at 9 cents per KW is $1.98. Your propane is probably more expensive than the electric.
You will probably want 2 "House" batteries, something that you will have a lot more roof for in a class C than a class B. Also you typically get at least 25 gallons and probaly 35 - 40 gallons of fresh water in a class C, while many class B's only have a 9-15 gallon fresh water tank. Class C will have a 6 gallon water heater, B might be 6 or smaller. Winnabego might have a engine heated hot water tank too, in a class C.
Fred.
Fred.
