ron_dittmer
Jul 31, 2013Explorer III
ScottMack wrote:Agreed.
Also, if you have a Ford chassis, you need to have the engine running when you turn the chassis heat/air off - otherwise, the vents do not close and you will have a major entry point for the cold air (or hot air in the summer). Ford uses the engine vacuum lines to physically close off the system from the outside air.
Turn this dial to the "OFF" position and the front cab area is closed off to the outside. Just be sure you turn it off 10 seconds before you turn off the engine to give it time to move the internal louvers with the vaccuum system.
