Dakzuki
Jul 31, 2013Explorer II
GENECOP wrote:rockhillmanor wrote:
None of them are! :B
They ALL have windshields and trust me they do NOT make windshields and side windows out of thermo pane glass. And I've yet to see even the high end "so-called" winter RV's that have an option to keep the hose you are connected to city water from freezing. :W
Yes it can be done in a MH but a lot of work on 'your' part has to be done to prevent you and your family from freezing or at best not being cold all the time and without running water.
It's not heaven but the Triple E allows you to close off the driver compartment, tanks filled with water (no hose) good to go, well insulated , a little LP consumption, but it works fine....
If you're creative you can close off the driver compartment or just the cab part.
The easy way is to hang a blanket from above blocking the cab. It is surprisingly effective.
A more involved way is to make fitted curtains that snap up in place like this.
