scrubjaysnest wrote:
We had a class c and are thinking about a B in the future when/if the TM no longer works for us. The problem as we see it is you have to make up the beds every day.Put up the bedding to use the rest of the camper, get it down and make the beds for sleeping. It was a hassle with the C and what stops us pursuing the B route at the current time.
Might I suggest you look at the Leisure Travel Van website.
We have a Regency on a Ford chassis which is the forerunner to the newer floor plans now available. Ours has a Murphy bed which is an excellent option. The bedding is left on and it takes only a few seconds to drop the bed for night time use. In the morning the sheets, blankets just need to be smoothed out, release a latch and lift the bed back into the upright position and latch it closed. It is so easy and gives you room to have a full bathroom and floor space. The only disadvantage is that couples have to have the same sleep pattern.
