mfjensen's avatar
mfjensen
Class Bs under 7'9" tall?
I'm looking for a class B that I can fit in my garage. I could do up to 24' long -- it's the height that's a killer. 7'9" is the absolute max. All the ones I see are over 9' high. Any suggestions? Marlene
  • Thank you all for the help! I didn't know about Sportsmobile -- and their conversions of the Ford Transit van will actually fit my low height. Again, thanks so much!
  • My garage is nine feet tall. My Roadtrek 210 clears by a few inches. I look at the other Bs and it is a no-go. I like the new ProMaster Bs like Travato but they are half a dozen inches too high and the design of the garage cannot be modified. If I built again, that door would be at least 10x10.
  • Most all the popup B's should fit. The Sportsmobile with 2wd and popup is around 6' as I recall. I had a similar restriction but my limit was 9'4" and I found a lot of the hightops fit that need as long as you stay away from Sprinter based B's. I ended up with an older Jayco, based on Ford E250 at 8'6". Really liked the Spotsmobile popup but the ones I found were higher than I wanted to spend.
