mlts22 wrote:
The shortest I've seen on the E-350 chassis is the Thor Axis/Vegas, but that is 26-28 long... and with how parking spaces are, 25 feet is the utmost limit, so anything longer than that, might as well just go 31 feet and enjoy the added room available.
Our rig is 23'-8" end-to-end and it will not fit in a regular parking space unless we are fortunate enough to find a space we could back into and let the rear over-hang grass or other. And since we tow most often, it is rarely applicable. Still we appreciate the shorter rig for a larger selection of campsites in national parks and such. We can almost always fit both the motor home and Jeep onto the same camp site. I don't recall ever separating the two. The short standard Ford 158" wheel base on the mo-ho also helps with hair-pin turns on mountain and canyon roads. My point is, bigger is better unless you spend a lot of your travels in national parks, monuments, etc. where "bigger" can limit you.
