Bordercollie
May 16, 2013Explorer
When your generator is not running and you are not hooked up to 110vac external power, all your 12 volt dc stuff is powered by your 12 volt DC house batteries. When your generator is providing 110vac power or you are hooked up to 110vac camp power, your "converter" is providing 12 volts dc to your 12 vdc stuff (lights, controls, etc) (through your house battery) and it is also slowly charging the house battery. When you run the engine, it's alternator charges the starting battery and house battery. Your "auxiliary battery switch" must be in the "on" setting for the house battery to power lights, etc., and be charged by the converter. Test the whether the house battery is charging with a cheap digital multi-meter/voltmeter on the DC volts setting, usually in the 20 volt range.
Dead battery reads 12 volts, charging battery reads over 13 volts, with engine running , charging battery reads up to 14 volts.
PS: With most RV's the engine starting battery is charging only when the engine is running, not being charged when RV is connected to camp power.
Hope I understood the questions and that this helps.
38,782 PostsLatest Activity: Sep 10, 2026
