xpjet96's avatar
xpjet96
Class C Handling Mod To Do First
I know there are going to be some varying opinions, but I only have so much available cash at a time to throw at all of the different mods I'd like to make to our newly acquired MH. I first want to address the handling characteristics and fully intend to do them all, but which to tackle first? Steering stabilizer, sway bars, or the heavy duty shocks? Picked up a used 32' Winnebago that looks almost new for a 2011 and would like it to drive as great as it looks.
  • Before doing anything, drive the used unit on the highway for many miles at 60-65 MPH with trucks passing you several times. Not a windy day. Check to see how it behaves on the road. It is possible that the unit may have had some improvements made all ready. I purchased a used 32' 2004 Winnebago. I have personally driven it over the highways over 6000 miles and it handles perfectly. I check the tire pressures before every trip and the tires are new.
  • The first and cheapest thing to do is to have it weighed,front and rear and each corner if possible in traveling configuration,fully loaded as you would when heading out on a trip,then adjust tire pressure according to a Load and inflation table
    Then you will have a great starting point to go on to new Bilstein shocks and proper alignment for your rig,then go on to sway bars and steering stabilizer.
  • make sure the tires are good, and if there are airbags installed you play with air setting to find best combo. I have a 12 aspect and it liked to wander, but it turns out the rear airbags and tire pressures had the most influence. 65psi F, 70-75 in rears, airbags at 55psi work for me as we dont load heavy.
    Considered the sway bar upgrade, new shocks etc, until I found what worked. really costs nothing but fuel to figure out.
  • I would start with heavy duty shocks. Bilstein made a huge difference on my 2012 E450.
