pushtoy_2
Sep 08, 2019Explorer
rgnprof wrote:a company called sumo makes heavy duty bump stops
Thanks for all the quick replies!
I ran the air bags at about 80 lbs - this typically raises my coach only about 1 1'2" - maybe 2"...
My shocks are Bilsteins - I installed them around 2011, 2012 and about 30k miles ago.
I have called 3 different online places, the last being Deaver (thanks bear). They were very helpful and to confirm Drew, they said that it's hard to just look at the springs and see a problem and that most likely the problems with these springs are the bushings! They said from new they have little "curve" to them...
He actually suggested adding a leaf - they have a kit specific to my application. Replace the bushings if needed, but he said they frequently don't because they're ok. The factory tapered 3-leaf spring is rated at 3450 lbs, so it's likely the coach has always been 'under springed'...
I'm strongly considering this route.
I would like to find some replacement rear frame rubber bump stops - mine have clearly taken some punishment. But, I'm having trouble finding these - my Ford dealers around are pretty much a waste when it comes to parts for this old coach.
38,782 PostsLatest Activity: Sep 10, 2026
