Cider's avatar
Cider
Class C Recommendations / used
Been RV'ing for a lot of years and have always had towable, mainly 5th wheels. We are now consider going to a class C as the 1 year old 5th wheel we now have just sits and does not get the use due to time constraints. I am thinking it would be simpler with a class C vehicle. I of not plan on towing another vehicle, at this time. There will be primarily just the wife and I with a small dog. I will probably buy used as I am going to take a big hit on the trade in of the 5th wheel. I would prefer a diesel engine due to lifespan and mileage, but am interested in pros and cons of gas vs diesel, aside from fuel cost (currently have a F350 SD diesel). What are good used models, probably in the 27 - 31 foot range. Are there particular limitations concerns over the shorter models that end up being deal breakers long term? I know, lots of questions,, but never having dealt with motorhomes before, I am in a new realm here. Appreciate any insight offered.
  • DrewE wrote:
    A fair number of people here have gotten and been very satisfied with ex-rental class C's from e.g. CruiseAmerica. There's a long thread on these units here. It's an option that IMHO is worth considering; the prices are generally fairly competitive, and the rental companies (at least the major ones) do a fairly decent job of maintenance.
    DrewE makes some very good points,and Here is that thread about Former Rentals,They are another option to look at.
    There are over 70 owners on it and all are happy with their decision.
    Good luck in your search.
  • DrewE's avatar
    DrewE
    Explorer III
    You will find very few if indeed any diesel class C's in the range you're looking at. The diesels available are generally either based on the Sprinter platform (which would be a bit undersized for most in your length range) or else super-C's based on heavier truck chassis. The vast majority you'll be looking at will be on Ford or Chevy van chassis, more often Fords, and these are gas only (unless quite old).
    That being said, you're very unlikely to ever put enough mileage on a motorhome to wear out the engine. Both the Ford V10 and the Chevy V8 are quite reliable and well-proven engines that will typically run a long time without significant problems if given reasonable basic maintenance.
    The main tradeoff for a shorter model is the obvious one of interior space and hence appointments. Much below 27' and you won't find a center bed in the back (mainly because there isn't room enough in back of the wheel wells unless the rear overhang is excessive). With any class C, it is very wise to check the weight and balance and cargo carrying limitations; some have not much payload at all left for you and your stuff.
    Do of course take the unit for a test drive. The motorhome will definitely not be as maneuverable as your truck, and most likely slower overall. Class C's tend to have pretty abysmal minimum turning radii, unsurprisingly worse as they get longer.
    While it is likely a little bit simpler to hop in a class C and go camping than it is to hook up a fifth wheel and head out, there's still a good bit of prep work involved. It generally takes me at least a few hours to fill the water tank, check the tire pressures, put food in the fridge and cupboards, get clothes together and stashed, and so on. I would give some hard thought to how much you'd actually gain in additional use and see if it's worth the financial hit you're (apparently) going to be taking.
  • People buy diesel engines for the towing/longevity/long travel advantages .. none of those are particularly suited for Class C. I have owned Class C for several decades - towing is a constant issue often because the frame limits towing capacity .. buying a bigger/better engine doesn't solve the problem.
  • Check out Lazy Daze Class C. Made in southern CA. No dealers. Sold directly to buyer. GAS only.
    They have a strong following and are very popular and high quality. Sides are made of painted alum. sheet metal.
    $91k to 105 k brand new for 2017 models. Of course, you can save by shopping used. Good Luck
    Here are floor plans...
    http://www.lazydaze.com/flrplans.htm
  • if looking at a C, check to see if roof has leaked, is leaking, or perhaps it will start.
    bumpy
