Mich_F
Nov 02, 2014Explorer
According to Remco the only 2010 Explorer that can be towed four down is the 4WD model and that requires a Ford neutral tow kit which is no longer available as far as Remco knows. RWD and AWD models have to be towed on a trailer. Towing on a trailer will most likely put you way over what your motor home is rated to tow by Four Winds, which is probably 3,500# at most. I'm sure Ford had a significantly higher GCWR than what Four Winds rates it for. Even without a trailer a base Explorer is over 4,500#.
38,782 PostsLatest Activity: Sep 02, 2026
