TripleClamp's avatar
TripleClamp
Class C Slide Out Seals Regular versus Offset
One of our seals needs replaced. It's the D type that slides onto the rail that is attached to the RV not the slideout. It appears to be the offset type. It's black. I can only find white:
D Seal with Offset
Here's the regular non offset:
D Seal with Offset
It appears they were replaced at one time. The offset part, instead of being on the outside, is on the inside on the left side of the slideout. On the others, the offset is out on the right.
Can I use the regular non offset type? Will it still get squished properly?
