et2's avatar
et2
Classic Brake Buddy issue
Our brake buddy just turned a year old in July. Today when hooking up it I was putting it through the 5 times pressing of the test button to get the green light that it's set to tow. Well after the 5 it shut off no display and the seventh sensitivity light was flashing red. Disconnected the 12v plug from the socket and got the same thing twice. The plug at the connection was red indicating it had power.
Looking at the manual it said it was because of a seriously low battery that it shuts it down. Well there was nothing wrong with the car battery as it starts the car and runs accessories fine. The car is fairly new, 8 months old and never ran down as there is a safety feature that shuts the electronics down. We drove the car for two hours the day before.
So I check the checked the car battery and everything is tight. So I go back in the car, plug it back it and go through the procedure again ... And it worked.
Has anyone had this issue with the Brake Buddy Classic? I know legally I'm not suppose to tow without a braking system for the toad. But I sure thought I was going to be in a pickle. No way the wife would drive the toad 4 hours home. So it was take it easy going home or be stranded until it was fixed.
Please keep this a Brake Buddy discussion. I'm not interested in other systems at this time.
Thanks!
  • Is that a home run outlet? Those compressors draw allot of current. Checking the voltage at the battery is often quite different than measured at the 12v outlet the BB is plugged into
