- ValkyriebushExplorer II
Swampman597 wrote:
Valkyriebush wrote:
our BT will go about two weeks from empty (like clockwork) before needing to be emptied with DW and I on board.
Whatcha expect? The poor black tank doesn't have a chance. Everyone knows Master Chiefs are full of******AND Command Master Chiefs are really full of it.
Ha-ha, Mike howzit going?
Mike
LMAO, Hey Swampman! Don't be disclosing Chiefs Mess secrets. lol Good to see you on the forum Mike. - JopopsExplorerI've heard excellent things about the GEO method. I'm going w/ that this year. Last year Happy Camper seemed to do a good job w/ my tank, but GEO makes more sense to me if you google it and give it a good read.
- icanonExplorerSome people swear this solved their Sensor problem.
I have never used it but it seems logical. - OldmeExplorerLots of water and Dawn Liquid.
Also add some "dish washing liquid" that
has sheeting action. If you can find Calgon
Water Softener it will also give you the sheeting
action you need to get the scum to glide off the sides.
They read incorrect because the scum completes the electrical
circuit to tell the sensors to activate.
Also crushed ice added while you drive will agitate and help clean. - DrewEExplorer IIThe wand thingy seemed to work for me. I would imagine a good thorough soaking beforehand (filling the tank with water and letting it sit) would help loosen crud. I've also read that automatic dishwasher detergent is sometimes helpful. Seems it might be worth trying in the pre-soaking, and at any rate wouldn't cause any problems.
- kendall69Explorer
gbopp wrote:
The Geo Method helps.
I don't really worry about the reading on the sensors. You'll quickly learn when you need to dump your tanks.
Geo method worked for me for 20 plus years. If it's really BAD tank with dried on "gunk" use clear water ONLY but pot in some septic tank enzymes that will "eat" the crud or at least soften it.
A day or two before a trip I load it up with the soap, water softener, pineSol, detergent, etc, and I add a couple of bags of CRUSHED ice, this does the scrubbing.
Drive around, let it sit, flush three times with clean water, then add some water and new toilet chemicals. Works in all tanks. - gboppExplorerThe Geo Method helps.
I don't really worry about the reading on the sensors. You'll quickly learn when you need to dump your tanks. - jfkmkExplorerCheck out thefitrv for a video showing the effectiveness of ice cubes in the black water tank.....not very. It is an entertaining video, though.
- ScottGNomadI've tried everything including every caustic cleaner I could find. None worked.
Finally I made my own "wand" out of some 1/2" PVC pipe with a cap on the end and a 3/16 hole drilled into the side of it. The end that attaches to the hose just used a 3/4" threaded PVC cap.
The force of the water coming through that little hole does a great job. My DW watches the sensor reading while I blast away at it. only take a minute and it works perfect again.
For a while. - Swampman597Explorer
Mike
38,760 PostsLatest Activity: Nov 14, 2025
