mkguitar
Sep 17, 2015Explorer
contact cleaners can be great -and many of them inhibit further corrosion as above .
some of them are not plastic safe- so look at the can.
I have a stash of old cramolin and blue shower-
I see you live by a large body of water, than could be where your corrosion is coming from- not much you can do there...
right on about the sensors, most run a 5 volt control voltage...the o2 sensor output usually is about .5 of a volt- and very low current so any resistance can cause problems.
Mike
Mike
