Durb
Sep 05, 2021Explorer
D.E.Bishop wrote:
In reply to Durb's comment about steel wool scratching your glass, not if you use the correct wool. I am a sawdust maker and the father of a daughter with a mid-century modern home that has a lot of floor to ceiling windows and a lot of landscaping. There different grades of wool and different materials. I use 0000 bronze wool almost exclusively for finishing lacquer surfaces on things I build. I found an oxidation remover for glass that recommends bronze wool with their wash.
I also use a magnifying glass and inspect the wool for imperfections. When my wife's car was sprayed by a friends lawn sprinklers and spotted very badly, the detailer used steel wool on the windows.
You just need to be careful using any kind of metallic wool to clean anything.
Comment regarding steel wool on glass is from an unfortunate experience during my youth and my sister's '63 Ford Falcon.
I'm also a wood butcher and have never used bronze wool but I don't spray lacquer. My finish of choice on nice hardwoods is to use multiple coats of Watco Danish Oil after sanding with 1500 grit. I rub it down with 0000 steel wool and apply a fine wax.
