Solo
Aug 29, 2015Explorer
DAS26miles wrote:
Really, no one every scrapes their levelers?????
No issues with our Winnebago Aspect. A lot of variables here with departure angles and what exactly you may run a tire over but, with our coach, I am right at Big Foot's recommended clearances and all has worked well. No problems with inclines on driveways, dips in roadways, etc. Big disclaimer here. check your departure angle-visually draw a straight line from the bottom of the rear duals on the ground up to the rear of your coach. Is there any part of the leveling system that is lower than that point? If so, you could have some issues. I was able to install mine high enough both front and rear to work as the company intended. Big Foot is a great system.
38,771 PostsLatest Activity: Apr 15, 2026
