- Desert_CaptainExplorer IIIA tip from my boating days... When you are attempting to seal anything keep in mind that the caulk product is there to form a gasket not to glue things down. You should apply the caulk and lightly tighten the screws/bolts etc., and then let it cure for 24 hours. Then after it has cured tighten everything down.
If you apply and then tighten you merely squeeze the caulk out from where it needs to be.
By waiting until the new "gasket" has cured before torquing down the fasteners you get a long-lasting watertight seal.
:C - ScottGNomadYou should be able to seal the lights without any sealant being visible. Remove the lights and seal under them. Wipe away any excess that squeezes out.
- camperdaveExplorerglad you found it!
- Dick_BExplorerOne of the first things I did when I took possession of our RV is to caulk the top and sides of all of the clearance lights. That stopped the leaks but now all of the caulk is an ugly black and won't clean off. I wonder what paint would stick?
38,712 PostsLatest Activity: Apr 06, 2025
