Geocritter's avatar
Geocritter
Clearing the black-water dump valve
I’ve enjoyed traveling and living in my RV for over 1.5 years now. During that time I’ve kept up with other peoples RV problem issues posted on this board. One common one is a leaking dump valve on their black-water tank. So far mine has been fine, though I dump about every 3 weeks. Early on I noticed that after a dump it was often difficult to close the dump valve and I suspected residual debris was partially blocking the valve. What I’ve made a habit of doing is that every time I dump I close the valve and fill the tank with 4-5 gallons of fresh water and then open the dump valve a second time to clear out any residual debris. Invariably after the second dump the valve shuts smoothly and so far (knock on wood) I haven’t had leakage problems.
Steve
  • You need to keep the valve shaft lubricated. I keep a jar of petroleum jelly in the wet bay. I use it to keep the o-rings, hose washers, and dump valve sealed and lubed.
  • I, too, back flush with the grey water but I do it all with the pressure in the full grey tank. I begin by dumping the black only when the grey is full. I dump the black first and, after it is empty, I pull the handle on the grey which allows the grey to rush up into the black. Even though some runs out the slinky, of course, there is plenty enough pressure to shoot straight across into the open black tank. After about 5 to 8 seconds, I close the grey valve and watch the water (and more) run back out of the black tank. When empty, repeat. With a full grey tank, I can do this 4 or 5 times and still have plenty of grey left to run through the slinky to flush it. I use a clear elbow between the outlet and the slinky to see what's going through and it didn't take much practice to get a feel for how much to successfully flush the black as well as when to stop the back flushing because the grey was beginning to run out. If you do this, you will see lots of black sediment and some paper run out and, with each successive cycle, you will run more and more clear. Noticing how much comes out on the first back flush, you will wonder how that black valve didn't get jammed each and every time (prior to using this method). One final tidbit... I close the black tank valve before the last grey flush runs out thereby trapping some grey water in the black tank. By the way... I do have the on-board black tank flush but, using the above method, I've found it's just not necessary.
  • Before I leave home, I put about 5 gallons of water in the black tank. By filling the toilet to the top 5 times and opening valve. Water in tank helps to clean out black tank while moving, and I have never had a problem when I dump.
  • That's a good solution and should work every time. Another technique is to use the grey tank to back flush the black valve. Some people install a third gate valve to do this, but I just hold the stinky slinky up above the level of the tanks and open the grey valve and let the tank levels equalize. Once flow has stopped between tanks, I close the grey valve and drop the hose. You can do this a few times, but once is usually enough. Finish up by draining the grey tank.
