pmlevine's avatar
pmlevine
Black Water Valve Will Not Close
It was our last TT trip of the season - all was well, I had opened and closed the black water valve at our campsite a couple of times with no issues. The last day after emptying the black water tank I went to close the valve and it wouldn’t budge. When I applied some force the valve rod bent. I straightened it as best I could and tried to close the valve but the metal rod will not move. Now the rod interface at the frame is loose - the threaded hollow screw at the frame that the rod goes through, the and the nut that secures it to the frame are loose, and I don’t seem to be able to tighten it up. Any ideas guys - help ..:
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
