Gjac
Nov 11, 2021Explorer III
I drilled a small hole in the top of the valve and put a self tapping grease fitting in there. When every it gets hard to open I pump some grease in there and it operates smoothly again. For some reason it is always the black valve that sticks never the gray valve. You can also just drill a hole and spray lubricant in the hole and put a screw in the hole after the valve is freed up.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
