bvail's avatar
bvail
Click noise under hood
97 Bounder, keep hearing a "tunk" followed by a "click" every few minutes under the hood when plugged into power. Sounds as if an automotive circuit breaker in the control box keeps tripping then resetting. Is this normal? If it is a breaker, how can I narrow down which one? Looks like I have to remove the circuit board to see some of the things behind it.
  • Open the battery control center. Look for two auto reset circuit breakers that feed the coach batteries. Some have two wired in parallel to carry the load.
    Which battery control center do you have? Make and model? Look on circuit board for model of it.
