NamMedevac_70
Aug 30, 2021Explorer II
rk911 wrote:
simple things first. i'd clean and tighten the starting battery terminals. the clicking noise could be a bad solonoid or it could be a dirty, corroded or loose connection.
Excellent suggestion. I just recently had this same problem on a Dodge Ram 1500 and the battery cable connections at the bat terminal were rotten. Battery and Alternator were working just fine. Sometimes they are just loose even if you think they are tight so double check again.
38,782 PostsLatest Activity: Aug 23, 2026
