John&Joey wrote:
Saw your reply and got me thinking once again (ouch.) Prior post mentioned that the oil pressure was greater then the cooling system.
Yes, that is true only when it is running. What happens is once you turn off the engine, oil pressure goes to zero, but your cooling system stays pressurized till it cools down. So it has all that time to sneak antifreeze into your oil system.
So once again keep an eye on the oil. If that thins you'll do some real $$$ damage.
Thanks for this incite, I suppose if this happens should I see it on the dip stick or oil cap? Kind of a white creamy build up?
