DrewE
Oct 05, 2016Explorer III
Do the things the fuses purportedly control cease to work when you pull the respective fuses? If so, then obviously they haven't been rerouted or anything and there's something not quite right in your testing procedure. Maybe the source and load sides of the fuses are the opposite from what you were expecting or your test light ground lead came loose or something like that.
38,769 PostsLatest Activity: Mar 31, 2026
