MrWizard
Oct 06, 2016Moderator
That is a sub panel
There is another larger fuse feeding that
And possibly a relay
Goto the main panel under the front hatch or under the dash
And find the feeder fuse
Check the large blade fuses 40, 50, 60 amp
Pull them out and check then with a meter one by one
You might see that one is blown out
Did you also loose power to windshield wipers radio etc..
38,769 PostsLatest Activity: Mar 29, 2026
