dougrainer
Jan 06, 2014Nomad
31 MHD's are CHASSIS batteries and are NOT designed for the COACH system. You need Coach batteries that are deep cycle type batteries, that are designed for slow discharge and quick recharge. AGM's are way more expensive and if you have a standard CONVERTER may have a problem with recharge correctly. Inverter/Chargers usually have a way to set the charge for all the various battery types. Doug
38,782 PostsLatest Activity: Sep 10, 2026
