CVD's avatar
CVD
When To Replace Coach Batteries?
I had a little corrosion on the walls of my battery tray, so I took them out to inspect. No structural harm, so I scrapped, sanded, painted the tray; now ready to put the batteries back in. At what point does it make sense to replace them as a preventive step?
These are 4 Sam’s Club (Johnson Controls) 6V EGC2 batteries, manufactured Feb 09 (8 + years ago).
They’ve consistently used only a couple spoonfuls of water every 2 – 3 months (per cell).
After sitting in the garage a couple days, each still measured 6.32 to 6.35 volts. (Don't have a shunt&Trimetric type device to measure more accurately).
They’ve worked fine. With light electricity use, I’ve gone 5 – 6 days boondocking without running the generator (have single 140w solar panel).
There was a little corrosion on a couple terminals and in the horizontal seam just below the top cap. Easily cleaned up.
There is a very slight bulge on the two ends of each battery (exact same on all 4). Don’t remember if they were this way when I put them in years ago.
Bottom line – They have been working fine, but I wonder if it makes sense to change the 8 year old batteries at home when I’m ready (instead of on the road when I’d rather be doing other things)?
