Cruisineasy's avatar
Cruisineasy
Coach Battery
I have a 2011 31' Jayco Greyhawk DS. The coach battery is failing and needs to be replaced. It currently has a Marine Master DP 27. 650 Cold cranking amps. Since it only has one battery I would like something that will last longer between charges. Would one with 850 Cold cranking amps work better?? Any help on this would be appreciated..
