Mike_De
Aug 03, 2014Explorer
Coach Separating from Cab!
I have a Jayco 2003 3100SS with about 25k miles (had since new)...
Got an interesting problem just happened. While on a trip, I noticed the coach box separating from the cab, just on the passenger side - not on the cab top or driver's side. Opened up just under 1/2", enough that I could see the screws holding the forward panel of the coach to the door frame.
I pulled the cover panel inside the coach and tightened the 6 or so screws that hold the coach box to the passenger door frame. About 1,000 miles later, it opened up again. This time used larger screws and flat washers, since it was starting to pull through the plywood panel. Same thing happened again after a bit...
Now there are some pretty significant dents where the latest screws/washers are trying to pull through the plywood. I've looked underneath, and don't see anything out of sorts... nothing bent, pulled, cracked, etc.
The other thing that happened at the same time is that a piece of angle iron in front of the step now hits the step when it comes out/in. So something has shifted, just can't seem to find it.
HELP!! Any ideas of things to check from all you smart folks out there??
[/img][img]
[/img][img]
[/img]
