lordnorth
Feb 28, 2015Explorer
Coach WaterPump Replacement Question?
I want to replace the factory water pump in my 2011 Coachmen Mirada. Waaaay too loud.
Just doing a quick search on Amazon, turned up 3 potentials:
$75.39 -- Shurflo Fresh Water Pump Model 2088-554-144 12 Volts, 3.5 Gallons Per Minute, 45 Psi
$62.00 -- SHURflo 4008-101-E65 3.0 Revolution Water Pump 3.0 GPM, 55 PSI
$60.07 -- Five Oceans Automatic Diaphragm Water Pressure Pump 12v 3.5 Gpm, 45 PSI
I admittedly don't understand water/electricity flow so I can't figure out how lower pressure can produce higher volume given the same size of piping. But it seems to me that high volume/low pressure would be great if it existed...
Any thoughts or suggestions that anyone could offer?
Thanks!
Chris
Thanks!
Chris
