Dutch_12078
Feb 28, 2015Explorer III
Adding some vibration isolation to your existing pump will likely do more for quieting it down than replacing it will. The most effective method is to add a foot or so loop of soft flexible hose with a suitable pressure rating at the entry and exit ports. Adding additional rubber padding under the pump can also help. A couple of layers of old mouse pad material is reported to work well.
You can see the loops on the right of the photo below that I added when I relocated the pump in our Landau from the bedroom to the wet bay. The third larger loop is a suction line for adding antifreeze or filling the water tank from a bucket or other container.
38,777 PostsLatest Activity: May 19, 2026
