Hello all, Started slow at last gas stop. Few hours later stopped at rest area and since won't start. No click, no wirrs, nothing. Figured might be starter, so replaced. No change. I've checked al...
Use a multimeter to check for voltage at the starter solenoid and the starter relay while you have a helper turn the ignition to start. Do the rest of the ignition functions work correctly when you turn the key? Another possibility is the neutral safety switch. I hope you're back on the road soon.
