pnichols
Jul 13, 2020Explorer II
carringb wrote:
Larger Class Cs have moved exclusively to the Ford chassis. Since higher-end C's tend to larger, you won't find much on the Chevy. Coachmen offers one Premier floorplan on the 260DS floorplan only. All other plans are exclusive to the Ford. The Forester Classic is available only with the 2501TS and 2861DS plans on the Chevy. Other fancier makers are Ford only across the board, like Entegra and Coachhouse. The Jayco Grayhawk Prestige is Ford only as well.
FWIW - My sister has a 2020 Forester on the Ford E450 chassis. It handles great, tracks well regardless of conditions, is quiet, and the floor doesn't get hot. They must be using the upgraded doghouse now (previously this only went into passenger vans) and the exhaust manifolds have heat shields I haven't seen before. Probably used formerly only on the Ambulance package. Anyways... miles ahead of the 2015 I drove last....
Bryan ... for what it's worth ... our 2005 Itasca Class C on the E450 chassis also has heat shields underneath between the exhaust pipes and the underside of the cab floor areas.
However, I have no idea if they were installed by Ford or Winnebago. In any case, routing the A/C air flow to the floor in hot weather should control any hot floor situation. Doing this A/C air flow routing via the cab dash controls is NOT obvious. It took a few years before we discovered how to do it, but it's not needed much in our case due to the heat shields.
