- wa8yxmExplorer IIIIf you can not get the holes to line up one of two conditions exists.
One. rotate the motor the holes are not 120 degrees apart so there is only one way they fit.
Two: wrong motor - They do line up, but you have to be EXACT. It is very frustrating. You have to line up all 6(3 pairs) bushing barrels and then run the bolts thru. I use a cordless drill with the 10mm socket to help. I also soak the upper area with WD 40 before removing the old motor bolts and then liberally spray WD 40 into the threaded slots. Doug
- dodge_guyExplorer III had to open up the holes in the steps to make mine fit. They were off just a bit. I used a carbide bit on a die grinder. Just make sure you open them up in the right direction.
38,770 PostsLatest Activity: Apr 12, 2026
