Bill_Kirkbride's avatar
Oct 18, 2020
Coachmen Santara Capacities
I just purchased a 2000 Coachmen Santara 370 MB diesel pusher. 350 HP Cummins. It has a 7000 KW Onan gasoline generator.
I have downloaded the Owners Manual and searched the Internet to find out the capacities of all of the liquids. Diesel fuel tank, Generator gasoline tank, Fresh water tank, gray water tank, black water tank, propane tank, etc... I cannot find this information anywhere. Does anyone have the same type RV that can provide this information? Thanks in advance for any help. Bill
  • Drew E
    I thought the same thing, that the capacities should be shown somewhere. So far, no luck. As for the propane, I can probably figure it out by some of the writing on the tank as well as, the size. It is much bigger than a bbq tank. I'll keep searching but so far, nothing.
  • Many of those should be on the weight (CCC/OCCC) sticker which is often on the back wall of a cabinet somewhere. At the very least it would have the fresh water and propane tank capacities.
    The propane tank would also have the capacity stamped on the data plate on the tank itself. You'd have to take care to read whether it's the so-called water capacity or the usable capacity (which is 80% of the water capacity by volume).
